Old 11-05-2006, 12:30 PM   #1
leaking from under frig when frig w/ice maker was moved forward
Can someone help. This is my first time here. I am desparate for info on what to do. We pulled out our frig from the wall and water keeps flowing out from the bottom. We have an ice maker and I think it's coming from under neath that. What can we do to stop the water from continuing to flow/
Tzippy
tzippy is offline   Reply With Quote
Old 11-05-2006, 02:22 PM   #2
A couple things could be wrong. If there is a drip-pan located in the bottom of the unit, you may have tipped it when pulling it away from the wall. More likely situation is that you broke the tubing or connection for the water supply. There should be a valve to shut off the water. It may be in back of the frig or run from the supply line of a sink or other fixture by a length of tubing. Check these things and let us know what it was.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Ge Profile Side By Side Frig With Broken Ice Maker BDURR67 Appliances 4 03-17-2008 12:40 PM
