-   -   leaking from under frig when frig w/ice maker was moved forward (http://www.diychatroom.com/f7/leaking-under-frig-when-frig-w-ice-maker-moved-forward-4659/)
tzippy 11-05-2006 12:30 PM
Can someone help. This is my first time here. I am desparate for info on what to do. We pulled out our frig from the wall and water keeps flowing out from the bottom. We have an ice maker and I think it's coming from under neath that. What can we do to stop the water from continuing to flow/
Tzippy
majakdragon 11-05-2006 02:22 PM
A couple things could be wrong. If there is a drip-pan located in the bottom of the unit, you may have tipped it when pulling it away from the wall. More likely situation is that you broke the tubing or connection for the water supply. There should be a valve to shut off the water. It may be in back of the frig or run from the supply line of a sink or other fixture by a length of tubing. Check these things and let us know what it was.
