Leaking Tub Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-28-2012, 11:02 PM   #1
Rewards Points: 20
Leaking tub drain
I have a leaking tub drain. I have attached to pictures and circled in red where the leaks are coming from. The first one the leak is where the two brass pipes meet. The second one is from where it is threaded and the brass pipe is coupled to the pvc pipe. I know I will need to clean the corrosion off the pipe, but I'm trying to find the best way to fix the leaks. I want to do it right and not cut corners but if possible I'd like to fix these without removing the pipes completely. Thanks.
Daves92gt is offline   Reply With Quote
Old 07-28-2012, 11:56 PM   #2
Rewards Points: 558
Well if you want to do it the right way then in my opinion you would have to remove and install new.
epson is offline   Reply With Quote
The Following 3 Users Say Thank You to epson For This Useful Post:
oh'mike (07-29-2012), plumberinlaw (07-29-2012), VIPlumber (07-29-2012)
Old 07-29-2012, 12:27 PM   #3
Dave,
As Epson points out, the only way to insure no more leaks, is to replace.
VIPlumber is offline   Reply With Quote
Old 07-29-2012, 02:38 PM   #4
Rewards Points: 582
yes replace the waste and overflow drain assy.....easy and its the best way.
Old 07-29-2012, 03:56 PM   #5
Rewards Points: 20
Thanks for the advice. Replacing is the route I have decided to go. The drain plug does not work anyway, so this solves two problems in one shot. Looking online at replacement drains I see they come in different sizes. Where do I need to measure my old one to ensure I get the right sizing?
Leaking bathroom sink drain - how to fix? thinksincode Plumbing 11 02-22-2012 09:34 PM
Scupper drain installation advice needed miamicuse Roofing/Siding 9 02-11-2012 09:59 AM
Leaking around old drain pipe in basement spg Plumbing 1 08-16-2011 11:27 AM
Drain hose leaking supermex79 Plumbing 4 05-17-2011 07:19 AM
pedestal sink drain leaking sully Plumbing 2 02-05-2007 08:01 AM
