Leaking Tub - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-10-2010, 10:43 PM   #1
Leaking tub
My daughter's ceiling had a damp spot so a contractor opened up the ceiling and discovered that the leak is coming from the tub. He has proposed replacing the tub and ceramic tile in the bathroom.
My question is: can the tub be fixed with a glazing job possibly? This is a full tub and wall unit and it will be diffucult getting it out of her small second floor bathroom.any thoughts on a solution besides a total replacement would be appreciated!
Ronham is offline   Reply With Quote
Old 08-11-2010, 12:11 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 452
How did he determine its the tub itself and not the plumbing connected to it? 9 times out of 10 its the piping. Such as the waste & overflow, rotten p trap, or a tile leak at the top edge of the tub.
Old 08-11-2010, 01:29 AM   #3
Rewards Points: 352
The leak could be as simple as bad caulk or bad seal at the valve body or tub spout. For a leak you really need an experienced service plumber not a nail banger
plumberinlaw is offline   Reply With Quote
Old 08-11-2010, 10:50 AM   #4
Owner
LateralConcepts's Avatar
I agree. "Hey, you have a leak. Let's remodel your bathroom." Doesn't sound like the solution, just a nice paycheck for the contractor.
If he opened the ceiling, can you post a picture? Can you see where the water is coming from?
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 08-11-2010, 11:07 AM   #5
Electrician
Proby's Avatar
I agree with the others. Unless you tube is cracked, chances are a little plumbing or caulking will fix your problem.
I would talk to your contractor and find out exactly where the leak is coming from, chances are he doesn't know nor does he care. He's happy replacing everything.
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
AC leaking condensation leaking into furnace jrf0022 HVAC 1 06-05-2010 08:52 PM
Can't figure out where the toilet is leaking??? Interior? CostcoMan Plumbing 11 04-13-2010 02:47 PM
Leaking Box Window Omeleto Building & Construction 9 02-19-2010 05:40 PM
leaking roof couchguy Roofing/Siding 1 02-13-2010 05:43 PM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 09:53 PM
