Leaking Toto Toilet And Banging Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-21-2011, 09:42 PM   #1
leaking Toto toilet and banging pipe
I have a Toto toilet that has a slow leek (it keeps running after it's full but goes down the drain - ie not flooding my bathroom). We replace the valve piece and went to turn the water back on and it started banging. Is this a preasure problem or something else and is it an easy fix?
missMRWhite is offline   Reply With Quote
Old 11-21-2011, 09:49 PM   #2
Rewards Points: 6,652
The banging is what is called a Water Hammer.
Old 11-22-2011, 07:11 AM   #3
This is a DIY website, so we have to make assumptions when we give advice. If you have no idea to what we are referring, call a pro.
Check water pressure, cheap gauges available at big box stores, should be about 45-65lbs. Water hammer is commen with any appliance that has quick closing valves. There is usually and anti-hammer device where the water enters the house. This is often just a piece of pipe about 3' long with a cap on it. That is supposed to trap air and acts as a shock absorber. If that gets water logged, air dissolves into the water over time, it stops working. You need to drain down the system to let air back into that pipe, or add smaller anti-hammer devices at each appliance.
The toilet leaking is a separate issue. If it is just leaking down, the flapper valve is the usual culprit. If it is running into the tank overflow pipe, the water level needs to be adjusted to below that pipe. Both waste water, fix it.
Tags
banging , leak , plumbing
Pipe knocking when toilet flushed guykovera Plumbing 5 09-27-2008 08:17 PM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 07:55 AM
