Leaking From Top - Rheem Gas Hot Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-18-2011, 09:17 AM   #1
twags
Leaking from Top - Rheem Gas Hot Water Heater
I have a slow leak from the top of my Rheem gas Hot Water Heater. I have attached pictures to show where the water is coming from (red arrows). I believe they are the screw holes are for the flue but not certain. It's a slow leak that started sometime last night but in the morning I had water over 1/4 of my garage. The unit is about 8 yrs. old.
Any advise on how to troubleshoot / fix this problem or if this is a major problem. Thank you.
Leaking from Top - Rheem Gas Hot Water Heater-close-up-view-leaking-area.jpg   Leaking from Top - Rheem Gas Hot Water Heater-dsc03184.jpg   Leaking from Top - Rheem Gas Hot Water Heater-rheem-hot-water-heater-area-where-leaking.jpg   Leaking from Top - Rheem Gas Hot Water Heater-rheem-specs.jpg   Leaking from Top - Rheem Gas Hot Water Heater-top-view-leak.jpg
twags is offline   Reply With Quote
Old 06-18-2011, 06:42 PM   #2
Rewards Points: 1,520
I'd say you need a new heater and that it has one or more leaks in the tank.
bob22 is offline   Reply With Quote
Old 06-18-2011, 07:58 PM   #3
twags
Thanks Bob, got a new one today. Thanks for the reply.
Old 07-06-2011, 07:23 PM   #4
Rheem Water Heater Leak from the top
I have a Rheem water heater that is leaking at the top. it is not leaking from any connections in plane site most likely internal. Is there any way to fix this or is the water heater burnt and needs to be replaced?
Kman6 is offline   Reply With Quote
Old 07-06-2011, 07:53 PM   #5
If it's internal, then you'll have to replace it.
VIPlumber is offline   Reply With Quote
Gas Water Heater, water not hot enough - Thermostat or Sediment makunag Plumbing 15 08-28-2010 12:00 AM
Leaking Water heater bkeech Plumbing 11 08-02-2010 03:29 PM
Water heater keeps leaking out of TPR valve knac1234 Plumbing 10 08-14-2009 09:08 PM
Natural Gas Water Heater Leaking from Release Valve Pipe? psumike Plumbing 6 01-14-2009 08:18 PM
