Leaking Toilet And Seperate Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-26-2011, 09:26 PM   #1
leaking toilet and seperate pipe
This morning we our bathroom floor was soaked and we noticed that anytime we flush 1 of the 2 bathrooms water seeps out from the toilet where it meets the floor(bathroom in the basement) and there is a separate pipe in the room behind the basement bathroom that foul smelling water backs up out of. I snaked that pipe with my snake/drill for all 25 feet that I have but it did nothing. I put a drain cleaner in the pipe and still nothing has changed so everytime we flush a toilet my basement bathroom gets soaked.....HELP PLEASE
hydro is offline   Reply With Quote
Old 02-27-2011, 04:53 AM   #2
Rewards Points: 352
Time to either rent a big snake (3/4"x100') or if they seem to dangerous (and they are) call in the service plumber. i stay away from the big franchised rooter companies they tend to try to sell sewer line replacements. Sometimes that is what you need but usually not. If anybody tries to sell you a dig without running a camera down the line come back here for others input.
plumberinlaw is offline   Reply With Quote
The Following User Says Thank You to plumberinlaw For This Useful Post:
LateralConcepts (02-27-2011)
Old 02-27-2011, 08:25 AM   #3
Owner
LateralConcepts's Avatar
...and if they do run a camera down the line, tell them you'd like a copy of the video. Upload it to YouTube and share it with us.
I wouldn't go as far as to say the big "franchised" rooter companies are all bad. Some of the "technicians" however, will take full advantage of your situation. Sometimes exaggerating a problem to up-sell. They're typically paid commissions. So turning a $300 job into a 5 or $8K excavation makes for a pretty good day. Likewise, I've heard nightmare stories of technicians (crooks) using the same video over and over to sell excavation jobs.
Nevertheless, a camera down the line will give you the information you need to determine the appropriate solution; whether it's periodic maintenance with a cable or jetter, a spot repair, or line replacement.
Also a snake may not do the trick if the blockage is caused by a belly (low spot in the line). In that case a soft blockage would need to be cleared with a high pressure jetter.
Just to reiterate:
big snake...dangerous (and they are)
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
The Following User Says Thank You to LateralConcepts For This Useful Post:
plumberinlaw (02-27-2011)
Water Stopped Coming to My Toilet limitdiy Plumbing 3 10-18-2011 07:36 PM
Toilet venting Master Brian Plumbing 5 08-24-2010 12:05 PM
Finishing a basement bath Vent? Pump-up toilet connection heenanp Plumbing 0 03-23-2010 06:43 PM
