Old 12-07-2008, 11:15 AM   #1
Leaking Toilet Cistern/Tank
Hi Hopefully this is the right area for this question. I have recently replaced the inlet valve however Ive now found a small hole at the bottom of the cistern tank which leaks water over the floor. Is there a way of fixing the hole in the tank ( close to the base of the Inlet Value) or should i be looking for a brand new toilet cistern set.. Any help is much appreciated. Amelie
Amelie08 is offline   Reply With Quote
Old 12-07-2008, 01:12 PM   #2
If the tank is not leaking from a hole put into the tank by the manufacturer, it is time to purchase a new one. By doing a repair, you may come home and find a flood if the repair doe's not hold or a larger defect occurs.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
HELP - Seriously leaking toilet JAR Plumbing 3 11-03-2008 05:28 PM
Water leaking into septic pipe below toilet Gramps Plumbing 1 09-14-2008 10:54 PM
toilet leaking, maybe? Gramps Plumbing 9 09-14-2008 01:31 PM
Leaking pipe under toilet aprildawn Plumbing 4 01-21-2007 05:32 PM
