Leaking Toilet Cistern-flush Pipe Connection - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-23-2012, 01:36 AM   #1
Leaking toilet cistern-flush pipe connection
Hi All,
Because of a continuously running toilet, today I have replaced the Cistern Outlet Valve. The valve itself works perfect but for some reason I am unable to completely seal off the connection between the Cistern and the Flush pipe. The new outlet valve came with a new wedge washer (which I have placed inside the cistern), a new back nut, a new flush pipe ring and a new cap nut. I have installed everything according to instructions but there is still a leak between the back nut and the bottom of the cistern. I already went back to the DIY store to buy a new wedge washer but the problem still exists. Even installing 2 wedge washers, 1 on the inside and one on the outside of the cistern, doesn't help. I am now inclined to buy a sealant and seal it off that way.
Does anyone have any idea what I might be doing wrong? Your help is much appreciated as this toilet is driving me insane.....
Many thanks and looking forward to your solutions!
Cheers a DIY-er from Perth, Australia
willv is offline   Reply With Quote
Old 09-23-2012, 05:56 AM   #2
DIY staff
Rewards Points: 7,174
Is there a flaw in the porcelain?
That is an odd one----if you do use sealant--try 'Form-a-Gasket' or something similar---an auto parts store will have that---
Replacing flush valve on one-peice Kohler Toilet griffin2000 Plumbing 6 01-14-2016 10:43 PM
leaking pipe under upstairs toilet mike49 Plumbing 1 06-23-2011 10:03 PM
Toilet waste pipe leaking Louise2910 Plumbing 2 06-27-2008 08:48 PM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 08:53 PM
Toilet; Cistern to Toilet pipe ( Complete Novice) broke1973 Plumbing 1 07-15-2005 08:34 AM
