Leaking Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-19-2007, 06:18 PM   #1
Leaking toilet
Yesterday I found that my toilet had leaked around the base - maybe a cupful of water was on the floor, all around. Never happened before, and the toilet has been in place @ five or six years. I closed the water line and checked it today and it has not leaked again. There is water standing in the bowl. No leak when I flushed it today. It seems to be firmly in place, and the nuts are not loose.
Bad gasket underneath? Is this a DIY project? Other possible causes? Thanks.
vapros is offline   Reply With Quote
Old 06-19-2007, 07:50 PM   #2
Definately sounds like the gasket or wax seal. Turn the water off at shut off. disconnect from toilet. Then remove the nuts and pull the toilet (taking the water out first). Inspect to be sure there isn't any other damage to the floor or the water closet. Clean out the wax, replace the seal and reset toilet, you'll want new bolts and nuts.
Remodeling is offline   Reply With Quote
Old 06-19-2007, 08:10 PM   #3
Diesel Fitter
Rewards Points: 150
If you think that its not coming from flushing check the top end and the water line before pulling the base. I use toilet paper after drying everything well, if anything drips you'll see it. Lay it out in strips behind the bowl and around the supply.
mikemy6 is offline   Reply With Quote
Advice on commercial toilet install SoCalSwami Plumbing 9 05-15-2008 03:43 PM
moving basement toilet cibula11 Plumbing 10 10-20-2007 01:22 PM
Leaking pipe under toilet aprildawn Plumbing 4 01-21-2007 04:32 PM
Replacing a Toilet dandgluna Plumbing 8 07-10-2006 10:09 PM
Toilet; Cistern to Toilet pipe ( Complete Novice) broke1973 Plumbing 1 07-15-2005 08:34 AM
