Leaking Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-25-2010, 11:03 PM   #1
Leaking toilet
What do you do if a newly installed ceramic tile floor is too tall for the flange to meet the wax ring?
blindsey is offline   Reply With Quote
Old 06-25-2010, 11:43 PM   #2
Do something
D'Brie's Avatar
Is the toilet flange lower than the floor? If so you may be able to use two wax rings. If it's much too low, consider cutting the pipe, couple it and lengthen it to meet the floor.
D'Brie is offline   Reply With Quote
The Following User Says Thank You to D'Brie For This Useful Post:
blindsey (06-26-2010)
Old 06-26-2010, 07:45 AM   #3
DIY staff
Rewards Points: 7,174
Wax rings come in different heights---A wax 'extender ' ring might do it.Adding a small standard ring to the flange first--( carefully press it down to ensure a good seal) then the extender ring might be the answer.
Sometimes you don't need the whole height of the standard ring--just use a knife and slice off a ring of the right height.
Plastic flange extenders are available if the old flange is way below the floor.--Seldom need one though.
---Mike---
Old 06-26-2010, 10:01 AM   #4
Buy an extender flange. When you install it, on top of the existing flange, make sure you use a sealer between the two flanges.Then screw through the holes in the extender and attach it through to the subfloor. Double wax seals can leak and sometimes slide while installing the toilet.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 06-27-2010, 09:53 AM   #5
Owner
LateralConcepts's Avatar
I've never had a problem with double wax rings leaking. If you decide to use two, make sure they're nice and warm, which shouldn't be a problem this time of year. If they're not pliable enough you can fill the lav sink with an inch of hot water or so and let them sit for a couple minutes. I like the rings with the polyethylene flange, but you'll need to pull the flange out of the top ring or buy one without out the flange. Once you stack them on top of each other mold them with your fingers to seal the two together.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Can't figure out where the toilet is leaking??? Interior? CostcoMan Plumbing 11 04-13-2010 02:47 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet leaking at the base on floor John24689 Plumbing 4 10-19-2009 09:03 AM
HELP - Seriously leaking toilet JAR Plumbing 3 11-03-2008 05:28 PM
Water leaking into septic pipe below toilet Gramps Plumbing 1 09-14-2008 10:54 PM
