Leaking Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-23-2010, 12:15 AM   #1
leaking toilet
my toilet keeps running and filling up with water and I keep dumping it out. It has leaked onto the floor and through the ceiling. black lid inside toilet broke off. How do I get the water to stop overflowing onto the floor?
jraycher is offline   Reply With Quote
Old 06-23-2010, 04:02 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
You apparently have two issues.
A. The built-in trap of the toilet, or the drain line from the toilet, is clogged up or the excess water would simply be draining down the line without overflowing. Try a toilet auger to clear the trap. If that doesn't do it, you will have to pull the toilet and snake the line.
B. Replace the flapper ("black lid"). Cut the rubber ring off of the back of it and attach the two little "ears" onto the bracket hooks at the base of the overflow valve. (Works smoother that way.) Adjust the chain to where it just allows the flapper to fully seat and seal. (Excess chain length can get twisted and hang up and prevent the flapper from sealing properly.)
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Can't figure out where the toilet is leaking??? Interior? CostcoMan Plumbing 11 04-13-2010 02:47 PM
Toilet leaking at the base on floor John24689 Plumbing 4 10-19-2009 09:03 AM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
HELP - Seriously leaking toilet JAR Plumbing 3 11-03-2008 05:28 PM
Water leaking into septic pipe below toilet Gramps Plumbing 1 09-14-2008 10:54 PM
