Leaking Toilet??? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-26-2009, 01:15 PM   #1
waveblasternutcase
Leaking Toilet???
is it possible for the toilet to leak into the subfloor without any water showing up on the floor? i noticed the other day that on one side of the toilet, the floor is starting to sink. the dip goes about half the length of the toilet and around the back. the remaining floor is fine. the dip is not huge, but can be seen upon looking closer. it is an old toilet and i think that if i had to replace the wax ring i should also replace the toilet....
thanks in advance
WBNC
WBNC is offline   Reply With Quote
Old 09-26-2009, 04:43 PM   #2
Yes, it is possible. The floor may not be perfectly level and allowing the water to pool to one side. There amy also be a space between the flooring and the drain pipe and the water is seeping to that area. Removing the toilet and inspecting is the only way to tell.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 09-27-2009, 12:28 AM   #3
Household Handyman
Rewards Points: 1,408
Would you like to know how many bathroom floors I have replaced in the last twelve months due to this very problem? Many! "majakdragon" is correct. IF a toilet is leaking between the toilet and wax ring or wax ring and floor flange, then the water will seek the lowest level, an uneven floor will cause the water to go to the lower side. We are not talking about a floor that is out of level an inch or so, just a little bit will do. Pour a little water on your floor in front of the toilet and see which way it runs. Depending on what type flooring you have in your bath-linoleum, tile, whatever, it was installed on top of a sub-floor of some type. A floor that has suddenly had a "bump" rise up in it, or feels "mushy" is a likely problem with floor rot. Most of the homes I find a problem in can be diagnosed by crawiling under the home and looking at the floor of the bath from the bottom. I have seen plywood floors which have "peeled" out from the bottom until I wonder how they walk on the floor. Leaking toilets can also lead to rotted floor joist's, rotted sills, and in some cases a rotten floor under the tub they did not know they had. Major replacement problems. Check yours out soon and hopefull avoid any major damages. Good Luck, David
Old 09-27-2009, 02:41 PM   #4
waveblasternutcase
I was afraid you were going to say that! the floor is cushy around the side and back of the toilet all the way to the wall. when i pull this toilet, i am going to replace it due to age. the floor is level in front and on the sides of the toilet, but not in the back. if the water goes to the lowest side, then the floor slopes the wrong way. i am wondering if the valve on the wall is leaking inside the wall. I hate crawling under my house! LOL!!!
if it is the toilet leaking, it only leaks into the floor when you flush correct?
David
Old 09-28-2009, 12:40 PM   #5
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
Yes, if your wax ring is the culprit, it should only leak when you flush.
if your floor is "squishy" plan on doing some subfloor replacement also...
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 10-09-2009, 01:51 PM   #6
waveblasternutcase
well after spending some time under the house, i am not sure that it is the toilet that is leaking. the floor from under the house around the toilet looks fine. it is the floor around a drain in my wall that does not. not sure where that drain comes from since that side of the house is a single story. it looks like the issue is inside the wall!
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Water leaking from below new toilet C_J_GO Plumbing 12 09-27-2009 08:49 PM
HELP - Seriously leaking toilet JAR Plumbing 3 11-03-2008 05:28 PM
Water leaking into septic pipe below toilet Gramps Plumbing 1 09-14-2008 10:54 PM
Leaking pipe under toilet aprildawn Plumbing 4 01-21-2007 05:32 PM
