Leaking Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-30-2012, 12:07 PM   #1
leaking toilet
how do I stop my toilet from leaking water from the back of the tank somewhere?
dlampreda is offline   Reply With Quote
Old 06-30-2012, 01:08 PM   #2
the Musigician
DangerMouse's Avatar
You need to figure out WHY/WHERE it's leaking. It sounds like it could be the tank to bowl bolt gaskets inside the tank or the larger gasket between the two. Does it leak more when you flush?
DM
Old 06-30-2012, 01:15 PM   #3
Rewards Points: 14,294
*******link removed******* Please do not redirect our members off site.
Old 06-30-2012, 01:59 PM   #4
Lightfoot's Avatar
Rewards Points: 272
if it's a fluidmaster fill valve, i have had the small hose (runs from the valve to the fill tube) come off and the water sprayed up on the lid, then ran down the back. just a thought.
Lightfoot is offline   Reply With Quote
Strangely Leaking Toilet... OhmZoned Plumbing 4 01-14-2012 11:55 AM
Can't figure out where the toilet is leaking??? Interior? CostcoMan Plumbing 11 04-13-2010 01:47 PM
Toilet leaking at the base on floor John24689 Plumbing 4 10-19-2009 08:03 AM
HELP - Seriously leaking toilet JAR Plumbing 3 11-03-2008 04:28 PM
Water leaking into septic pipe below toilet Gramps Plumbing 1 09-14-2008 09:54 PM
