Old 03-17-2007, 10:40 PM   #1
leaking taps.
I would love some advice on which are the best taps to put in the copper lines i have put in valve taps and every time they are opened and closed they leak i was told that the lever type are best ?
P.S, they have only been installed for approx 1 year.
always something is offline   Reply With Quote
Old 03-17-2007, 10:54 PM   #2
leaking taps.
I've never seen a saddle-tap that didn't leak soon after it was put in. Maybe somebody else knows something I don't.
halibrand is offline   Reply With Quote
Old 03-18-2007, 04:38 AM   #3
Journeyman Plumber
Ron The Plumber's Avatar
leaking taps.
Where does it leak at?
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 03-18-2007, 09:35 AM   #4
leaking taps.
they leak at the shaft i was always told to open and close the valves
once every 6 months so this does not happen, maybe i should remove the valve a lube all the seals, or just maybe remove the whole tap and
replace it with a different style.
Old 03-18-2007, 01:08 PM   #5
Journeyman Plumber
leaking taps.
Tighten up the nut on the back side of the handle, that works everytime.
ball valve leaking bwall Plumbing 10 12-31-2012 08:25 PM
water leaking from pressure balance spool lauralyn1 Plumbing 16 08-13-2007 05:50 PM
Are roof skylights leaking? Halron Roofing 3 04-15-2007 03:06 PM
leaking bathtub mikeynholly Plumbing 1 02-11-2007 02:50 PM
Leaking attic gable vents MoMo Roofing 2 04-02-2005 10:00 PM
