Old 06-03-2007, 09:22 PM   #1
Leaking tank
I'm a "novice plumber" and have a leak in my toilet. I'm concerned that the spud should be more flush, but currently is raises the tank about 1/2 inch. This results in a tank that leans against the back wall, off-setting the two bolts that hold the tank down. This, in turn, results in a slow leak at these bolts.. (both have rubber washers on both sides..)
Do I need a "flatter" spud? Is there such a thing? I ask this because the other toilets in my house have much less room between the tank and toilet..
Thank you!
DCPete27 is offline   Reply With Quote
Old 06-03-2007, 10:05 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Leaking tank
What brand is this toilet?
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Old 06-03-2007, 10:45 PM   #3
Leaking tank
American Standard Plebe.. circa 1989
Old 06-03-2007, 10:49 PM   #4
Journeyman Plumber
Leaking tank
The AM/STD tank to bowl gasket is a thick one, pull tank and reposition the tank, tighten up in an even fashion, alternating from each bolt till it looks good, see if that fixes the problem.
Old 06-04-2007, 10:09 AM   #5
Leaking tank
Thanks for the info! Just to clarify: Do I want to tighten the two bolts so that the tank remains competely upright/vertical? Or is it okay for the tank to lean back towards the wall a bit? It would seem that the more it leans, the greater the likelihood of leaking.
But if I tighten it too tight, the ceramic may break....
Old 06-04-2007, 08:59 PM   #6
Journeyman Plumber
Leaking tank
Tighten up even both sides, no leaning, just snug them down, don't over tighten.
Old 06-04-2007, 10:31 PM   #7
Leaking tank
It invariably leans into the back wall.. Due to this I placed something between the tank and wall to keep it perfectly upright.
I've tightened, retightened, made sure the gasket was a good fit, over and over.. it will hold for awhile and then the leak begins.. Frustrating as anything! The washers are new, and it seems if I tighten more I may crack the tank..
I hate to do it, but I may be forced to call a plumber..
I appreciate your suggestions and time!
Old 06-04-2007, 10:39 PM   #8
Journeyman Plumber
Leaking tank
Is it leaking between the tank and bowl? It could be the flush valve gasket that is leaking making you think it is the tank to bowl gasket.
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Pressure Tank Question? cruzplanner Plumbing 3 02-11-2009 12:11 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
Magnolia tree + septic tank question/problem Jemo General Discussion 5 01-18-2007 10:08 AM
