-   -   Leaking tank (http://www.diychatroom.com/f7/leaking-tank-8917/)
DCPete27 06-03-2007 08:22 PM
Leaking tank
I'm a "novice plumber" and have a leak in my toilet. I'm concerned that the spud should be more flush, but currently is raises the tank about 1/2 inch. This results in a tank that leans against the back wall, off-setting the two bolts that hold the tank down. This, in turn, results in a slow leak at these bolts.. (both have rubber washers on both sides..)
Do I need a "flatter" spud? Is there such a thing? I ask this because the other toilets in my house have much less room between the tank and toilet..
Thank you!
Ron The Plumber 06-03-2007 09:05 PM
What brand is this toilet?
DCPete27 06-03-2007 09:45 PM
brand
American Standard Plebe.. circa 1989
Ron The Plumber 06-03-2007 09:49 PM
The AM/STD tank to bowl gasket is a thick one, pull tank and reposition the tank, tighten up in an even fashion, alternating from each bolt till it looks good, see if that fixes the problem.
DCPete27 06-04-2007 09:09 AM
how tight is too tight?
Thanks for the info! Just to clarify: Do I want to tighten the two bolts so that the tank remains competely upright/vertical? Or is it okay for the tank to lean back towards the wall a bit? It would seem that the more it leans, the greater the likelihood of leaking.
But if I tighten it too tight, the ceramic may break....
Ron The Plumber 06-04-2007 07:59 PM
Tighten up even both sides, no leaning, just snug them down, don't over tighten.
DCPete27 06-04-2007 09:31 PM
It leans
It invariably leans into the back wall.. Due to this I placed something between the tank and wall to keep it perfectly upright.
I've tightened, retightened, made sure the gasket was a good fit, over and over.. it will hold for awhile and then the leak begins.. Frustrating as anything! The washers are new, and it seems if I tighten more I may crack the tank..
I hate to do it, but I may be forced to call a plumber..
I appreciate your suggestions and time!:mad:
Ron The Plumber 06-04-2007 09:39 PM
Is it leaking between the tank and bowl? It could be the flush valve gasket that is leaking making you think it is the tank to bowl gasket.
