Leaking 'T' On PEX Line Need Bandaid Idea - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-24-2011, 09:15 AM   #1
Leaking 'T' on PEX line need bandaid idea
Discovered a 'T' that is cracked and I need to repair it today. But nobody is open on Thanksgiving, so how do I stop this leak without shutting the water off to the entire house? Can I duct tape it into submission for 24 hours?
Thanks,
Shane
Quackersnacker is offline   Reply With Quote
Old 11-24-2011, 09:20 AM   #2
Rewards Points: 582
shane you can try anything you like if you don't have any parts to work with...shut off water drain lines and start taping do it as tight as possible...then turn water back on to see if you slowed it down,,,
The Following User Says Thank You to ben's plumbing For This Useful Post:
Quackersnacker (11-24-2011)
Old 11-24-2011, 09:34 AM   #3
Thanks Ben, What should be my options for fittings when I repair this tomorrow?
Old 11-24-2011, 09:39 AM   #4
Rewards Points: 582
not sure what pex you have ...home depot, lowes have adapters and sharkbite fittings iam sure you can find something.....pics help...
Old 11-26-2011, 10:57 PM   #5
Thanks Ben ,
I threw down the $70 for Sharkbite clamps and Crimper and it was a snap! I won't need to use that tool very often but it sure made it easy for this application. And since all lines under my house are PEX I am sure this is not the last time I will use it.
Thanks,
Shane
Old 11-26-2011, 11:10 PM   #6
Rewards Points: 582
Originally Posted by Quackersnacker View Post
Thanks Ben ,
Thanks,
Shane
glad to here back from you was wondering how you made out sounds good glad to help.....
Proper Water and Gas line bonding. John318 Electrical 5 11-16-2011 12:19 PM
Outdoor Underground Natural Gas Line Vikeologist HVAC 13 10-26-2011 12:46 PM
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 11:21 AM
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 03:56 PM
electric line and gas line couch potatoe Electrical 17 09-30-2008 11:43 PM
