Old 07-05-2010, 09:49 PM   #16
Doing it myself
Alan's Avatar
Leaking T&P Valve on water heater
Sorry, our shop doesn't have a boiler license, so I'm not familiar with the codes on them. First of all your Drawing has the inlet/outlet of the water heater backwards, and I don't see an inlet/outlet on the boiler, so i'm confused on how that system is actually plumbed.
In regards to your original problem, it could be the main PRV has gone out then, so check the pressure on the house at a hose bibb.
Journeyman Plumber
Old 07-05-2010, 10:43 PM   #17
Just call me Andrew
I'm pretty certain i have the water heater feeds drawn as they are in the house.
As for the boiler, after the baseboard heats, the line just loops back into the boiler (i left it out as i didn't think it applied to the problem).
Andrew
secutanudu is offline   Reply With Quote
Old 07-06-2010, 09:09 AM   #18
"This thing" in the diagram is ued to admit more water to the boiler when the latter's level gets too low. I think it is manual although they also make automatic ones. Water does not (should not) go through it the other way, from the boiler back into the domestic plumbing. The expansion tank shown serves the boiler only. You should install another expansion tank in the domestic water system.
If water comes out when you activate the air valve on an expansion tank below or on the side of the pipe it is attached to, most likely the tank is defective and must be replaced. If the expansion tank is above the pipe it is attached to and you can get most of the water out of it with the system turned off, then you can keep using the tank so long as you check it often enough that it does not fill up with water completely as the water will gradually absorb the air without a bladder in the tank separating the water and air.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Old 07-06-2010, 09:14 AM   #19
Just call me Andrew
Originally Posted by AllanJ View Post
"This thing" in the diagram admits more water to the boiler when the latter's level gets too low.
Is it just that it is lower pressure than what is normally in the boiler heating loop (hence the low pressure setting on the regulator, about 20 psi), so that water only can enter the boiler system when the pressure drops (ie. water gets low)?
The expansion tank serves the boiler only.
I believe you - but mind explaining how the water in the expansion tank doesn't make it into the water heater?
If I were to install an expansion tank for domestic hot water, where in the line would it go?
Thanks.
Andrew
Old 07-06-2010, 09:26 AM   #20
The regulator in between keeps boiler water (and in this case the expansion tank contents also) out of the domestic system, I think even if the boiler pressure should exceed the domestic pressure.
Another expansion tank can go anywhere in the domestic system although between the water heater cold water inlet valve and the water heater is the best place.
Old 07-06-2010, 09:31 AM   #21
Just call me Andrew
I didn't think to check the direction in which that regulator is installed. Or does the pressure reduction occur in both directions?
Andrew
Old 07-06-2010, 09:56 AM   #22
Doing it myself
Alan's Avatar
I didn't think that pressure regulators had check valves in them
Journeyman Plumber
Old 07-06-2010, 06:02 PM   #23
Just call me Andrew
If that's the case, how do the two systems not mix regularly?
Andrew
leaking pressure relief valve on heating water boiler benjamintr HVAC 13 01-29-2011 06:32 AM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 11:02 AM
Resource for understanding gas valve? darsunt HVAC 19 02-04-2009 12:08 AM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-07-2008 12:31 AM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 01:43 PM
