Leaking Stop Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-31-2007, 06:03 PM   #1
leaking stop valve
The hot water stop valve for my downstairs sink has a slow drip. It's a compression so I tightened it a little but it didn't help. I went a little tighter and still dripping. I don't want to go any tighter since I have to reuse the pipe again for a new valve. I know your not suppose to use teflon tape on a compression ferrell but for a quick temp fix could it really do any harm since the valve is shot anyway?? thanks
farrington135 is offline   Reply With Quote
Old 03-31-2007, 07:33 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
You can use teflon tape, there no problems using it.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
ball valve leaking bwall Plumbing 10 12-31-2012 08:25 PM
New ball valve leaking half open? sz8 Plumbing 5 01-05-2007 11:46 PM
Main valve not working. Water won't turn on! skellies Plumbing 1 10-31-2006 03:17 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
leaking 1 1/4" Brass Ball Valve creemore Plumbing 2 03-11-2005 09:23 PM
