Old 03-29-2010, 09:52 AM   #1
Leaking sink repair
I have a leaking sink in one of my bathrooms and I'm not sure how to fix it. I know where the leak is but I don't know how to actually get to it to make the fix, which should be really simple. The picture indicates the problem, what I don't know is if I need to take the entire assembly out to fix the leak or if there is some way to get the PVC off so I can tighten up the copper extension that is leaking. The sink is disconnected from the wall right now so its easy to get to everything.
cellophane is offline   Reply With Quote
Old 03-29-2010, 10:11 AM   #2
Doing it myself
Alan's Avatar
Leaking sink repair
That copper extension is called a tailpiece. You should probably pull off the j-bend part of the p-trap so that you can pull it off. You shouldn't have to use a wrench on it. Just use teflon tape about 4 wraps worth and tighten it back up to hand tight. Replace j-bend, and you're good to go, unless it's actually something else that is leaking.
Journeyman Plumber
Old 03-29-2010, 10:21 AM   #3
Leaking sink repair
That's what I thought. How do I get the J-bend off? I can't get my hand in there to grab the washer (?) to unscrew it and I can't get a wrench in to hold it... or does this mean I get to go buy a strap wrench?!
Old 03-29-2010, 11:10 AM   #4
Leaking sink repair
Place a flat blade screwdriver against the bump on the "washer" and tap the handle of the screwdriver.
zircon is offline   Reply With Quote
Old 03-29-2010, 03:06 PM   #5
Doing it myself
Alan's Avatar
Leaking sink repair
It shouldn't be tighter than hand tight. Get rubber palmed atlas work gloves. Hold with one hand, loosen with the other. Righty tighty, lefty loosey.
Journeyman Plumber
Old 03-29-2010, 03:13 PM   #6
Leaking sink repair
I can't actually get my hand in the sink base to do anything with it
I appreciate the feedback though! I'll give it a whirl tonight in between painting and see if I can't fix it.
Old 03-29-2010, 04:16 PM   #7
Leaking sink repair
can you just take the sink off the base make the repair then put the sink back on the base
plumberinlaw is offline   Reply With Quote
Old 03-29-2010, 04:20 PM   #8
Doing it myself
Alan's Avatar
Leaking sink repair
It might be more trouble than it's worth if it's caulked on... we usually do..
Journeyman Plumber
Old 03-29-2010, 04:39 PM   #9
Leaking sink repair
it's a single ceramic pedastal sink. that's why i was wondering if i needed to take the entire assembly out or if it could be fixed in situ. the sink is also 100% disconnected from the wall and is currently sitting in the middle of the floor.
Old 03-29-2010, 06:58 PM   #10
Doing it myself
Alan's Avatar
Leaking sink repair
A very small pipe wrench should fit in there. Maybe even an 8"
Journeyman Plumber
Old 03-29-2010, 07:23 PM   #11
Leaking sink repair
if the sink is off the pedestal you should be in good shape, yes?
The older I get the better I was
New kitchen strainer leaking on Kohlr Cast-Iron sink wysiwyg6000 Plumbing 2 01-04-2010 09:47 PM
Chip in Enamel Kitchen Sink Repair girlscandoittoo Appliances 5 10-06-2009 07:29 PM
How To Repair A Sink Ripped Out The Wall! ray0890 General Discussion 9 06-12-2009 04:17 PM
leaking sink drain dbldee20 Plumbing 6 01-08-2009 06:55 PM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 06:53 PM
