-   -   Leaking sink repair (http://www.diychatroom.com/f7/leaking-sink-repair-67843/)
cellophane 03-29-2010 09:52 AM
Leaking sink repair
I have a leaking sink in one of my bathrooms and I'm not sure how to fix it. I know where the leak is but I don't know how to actually get to it to make the fix, which should be really simple. The picture indicates the problem, what I don't know is if I need to take the entire assembly out to fix the leak or if there is some way to get the PVC off so I can tighten up the copper extension that is leaking. The sink is disconnected from the wall right now so its easy to get to everything.
http://img88.imageshack.us/img88/6153/sinkmarkup.th.jpg
Alan 03-29-2010 10:11 AM
That copper extension is called a tailpiece. You should probably pull off the j-bend part of the p-trap so that you can pull it off. You shouldn't have to use a wrench on it. Just use teflon tape about 4 wraps worth and tighten it back up to hand tight. Replace j-bend, and you're good to go, unless it's actually something else that is leaking. :thumbup:
cellophane 03-29-2010 10:21 AM
That's what I thought. How do I get the J-bend off? I can't get my hand in there to grab the washer (?) to unscrew it and I can't get a wrench in to hold it... or does this mean I get to go buy a strap wrench?! :clap:
zircon 03-29-2010 11:10 AM
flat blade screwdriver
Place a flat blade screwdriver against the bump on the "washer" and tap the handle of the screwdriver.
Alan 03-29-2010 03:06 PM
It shouldn't be tighter than hand tight. Get rubber palmed atlas work gloves. Hold with one hand, loosen with the other. Righty tighty, lefty loosey.
cellophane 03-29-2010 03:13 PM
I can't actually get my hand in the sink base to do anything with it :(
I appreciate the feedback though! I'll give it a whirl tonight in between painting and see if I can't fix it.
plumberinlaw 03-29-2010 04:16 PM
can you just take the sink off the base make the repair then put the sink back on the base
Alan 03-29-2010 04:20 PM
It might be more trouble than it's worth if it's caulked on... we usually do..
cellophane 03-29-2010 04:39 PM
it's a single ceramic pedastal sink. that's why i was wondering if i needed to take the entire assembly out or if it could be fixed in situ. the sink is also 100% disconnected from the wall and is currently sitting in the middle of the floor.
Alan 03-29-2010 06:58 PM
A very small pipe wrench should fit in there. Maybe even an 8"
tpolk 03-29-2010 07:23 PM
if the sink is off the pedestal you should be in good shape, yes?
