Leaking Sink Plumbing, Help! - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-26-2010, 08:50 PM   #1
Leaking sink plumbing, help!
This master bedroom sink is 5 years old. Thought I had lost an earring down the drain so took off the plumping joints to look for it. Put everything back together and now the top part plumbing leaks. This was above the black rubber seal. Took it apart again and noticed a wider tear at the top of the drain hole that seems to be attached to the first part of the plumbing from the top of the sink. There was a tear here before I started without the leak, now it is bigger, due to me twisting it most likely. Tried to upload pictures, but couldn't get them to upload.
Do I need to buy a whole new sink just to fix this?
Thanks.
Donedidit is offline   Reply With Quote
Old 09-26-2010, 08:55 PM   #2
no you don't have to replace the whole sink, just take the defective parts to your local home depoe or an equivilent place like that and one of their employees can help you. good luck...dw
dwhitead is offline   Reply With Quote
The Following User Says Thank You to dwhitead For This Useful Post:
Donedidit (09-26-2010)
Tags
leak , plumbing , sink
NEW sink and plumbing is slow draining, no overflow, pipes not clogged ymi2b Plumbing 15 09-10-2015 09:29 PM
Need help with sink plumbing profenx Plumbing 19 08-01-2010 05:35 PM
New kitchen strainer leaking on Kohlr Cast-Iron sink wysiwyg6000 Plumbing 2 01-04-2010 09:47 PM
plumbing a new sink kchiasson Plumbing 1 09-23-2008 04:04 PM
Need Help Plumbing A Utility Sink... drummereef Plumbing 17 07-29-2008 04:16 PM
