Leaking Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-29-2009, 10:11 PM   #1
Leaking sink
I replaced the faucet on my kitchen sink. When removed the old faucet the nuts holding it in were frozen, and the bolt started spinning with the nut. When the bolt gave I hit my hand and ratchet handle on the sink drain, now water is leaking from around the drain.
Can i just caulk around the bottom of the drain, or is there a gasket or seal that i need to replace?
Sliver is offline   Reply With Quote
Old 03-29-2009, 11:41 PM   #2
HVAC / Plumbing
If you are talking about the main drain for the sink... Yes there should be a rubber gasket where the drain attatches to the sink/ strainer
kenmac is offline   Reply With Quote
Old 03-30-2009, 01:54 AM   #3
G_P
its not just that rubber gasket. you should remove the drain assembly completely and redo the plumbers putty around the top and also replace the rubber gasket on the bottom.
make sure to clean off all the old putty before you reinstall.
G_P is offline   Reply With Quote
Old 03-30-2009, 07:01 AM   #4
HVAC / Plumbing
Mine doesn't have plumbers putty... It's rubber
Old 03-30-2009, 04:35 PM   #5
Thank you.
That is what I was thinking i just wanted to make sure, and I don't want to trust anyone from home depot to tell me how to do it right.
Leaking kitchen sink kevin-redsoxfan Plumbing 1 01-14-2009 03:41 PM
leaking sink drain dbldee20 Plumbing 6 01-08-2009 05:55 PM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 05:53 PM
pedestal sink drain leaking sully Plumbing 2 02-05-2007 08:01 AM
leaking under sink when dishwasher on Big B Plumbing 2 06-07-2006 06:36 PM
