Old 03-03-2010, 10:24 PM   #1
Still going...
ChrisDIY's Avatar
Question
Leaking shut off valve, am I that inept???
I put on two shut off valves for the kitchen sink today. The hot water side was done first. I wrapped the valve with a moist rag and did my sweat connection with, cleaning, flux and solder. I went to the cold water side and repeated the process, I actually put more heat on the cold water shut off valve. Later, I noticed I have a leak around where the 3/8" connection is to the water line for the faucet. There is a small seam where the threaded part of the valve is mated with the bulk of the valve. Neither sweat connection is leaking. I don't think my pipe sweat connections are done improperly.
Has anyone had an issue with shut off valves from Lowe's leaking? Seems odd that the valve that is leaking had less heat applied to it?
--Chris
--Chris the DIY Guy
Still going, on Ibuprofen...
ChrisDIY is offline   Reply With Quote
Old 03-03-2010, 10:37 PM   #2
retired elect/hvac/plumb
plummen's Avatar
did you check the packingnut?
plummen is offline   Reply With Quote
Old 03-03-2010, 11:04 PM   #3
did you reuse the supply lines?
plumberinlaw is offline   Reply With Quote
Old 03-03-2010, 11:06 PM   #4
Still going...
ChrisDIY's Avatar
Doesn't appear to have anything to tighten at this point??? See pic. Top water drop is forming right where water is coming out.
--Chris the DIY Guy
Old 03-03-2010, 11:10 PM   #5
Still going...
ChrisDIY's Avatar
Everything is brand new. All from Lowe's
--Chris the DIY Guy
Old 03-03-2010, 11:11 PM   #6
plummen's Avatar
looks like the valve is split ,is that brasscraft?
Old 03-03-2010, 11:18 PM   #7
Still going...
ChrisDIY's Avatar
No it's Keeney "Hecho en China"
--Chris the DIY Guy
Old 03-03-2010, 11:22 PM   #8
plummen's Avatar
id say theres your problem,i thought lowes sold brass craft
Old 03-03-2010, 11:32 PM   #9
Still going...
ChrisDIY's Avatar
I live out in the country and the first store I get to is Lowe's. I have a Home Depot another 20-30 minutes more. I will try the "Do it best Hardware" in the opposite direction which is a little closer than Home Depot. Will look for Brass Craft.
--Chris the DIY Guy
Old 03-04-2010, 07:42 AM   #10
Super Moderator
I tried that brand once--same trouble---junk---Mike--
oh'mike is online now   Reply With Quote
Old 07-28-2012, 12:17 AM   #11
hello I have a similar drip leak but this top part of the valve actually unscrews from the valve when trying to disconnect the supply line... and there doesn't appear any way to unscrew the top part of the valve from the supply line without destroying the threads with channel locks or vise grips/// I would prefer not to buy a whole new shutoff valve of course.. suggestions? thanks
Joe
Flotrain is offline   Reply With Quote
Old 07-28-2012, 07:24 PM   #12
not very good valves......just replace it with brasscraft.... seen many valves leak there all from lowes..
The Following User Says Thank You to ben's plumbing For This Useful Post:
oh'mike (07-28-2012)
Old 07-28-2012, 08:52 PM   #13
Still going...
ChrisDIY's Avatar
Joe
Can you post a picture? Sounds like a compression valve.
--Chris the DIY Guy
How to diagnose gas valve problems Nestor_Kelebay How To Guides 27 03-07-2013 03:17 AM
help! leaking shut off valve. LOST x913x Plumbing 5 03-02-2010 08:17 AM
New Compression Shut Off Valve for Toilet Leaking C_J_GO Plumbing 6 10-22-2009 04:30 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
new install shut off valve leaking ferris84 Plumbing 3 11-12-2007 04:47 PM
