Leaking Shower Tap - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-13-2009, 01:45 PM   #1
Question
Leaking shower tap
Hi,
I have an old house. The water is leaking from the cold water tap. When i Change the washer, it will not leak for 2-3 days and then it will start leaking again. I saw that the seat has a cut on its edge. I bought a seat removing wrench but the problem is that the seat is in a sleeve which rotates with the seat in the pipe. I asked a professional but he said this is an old system and he said that whole system needs to be replaced.
Can some one please help?
Thanks to all.
Tekno9000 is offline   Reply With Quote
Old 12-13-2009, 03:42 PM   #2
Are you sure it's "old"? Kohler still makes valves with that type of removable seats:
http://www.kohlerserviceparts.kohler...e3869032a4aa98
You can blow up the image using the magnifying glass icon on the left hand side. (check out parts #30134 and 30135)
Ishmael is offline   Reply With Quote
Old 12-13-2009, 07:15 PM   #3
Hi Ishmael,
THe diagram preety much resembles the tap I have but it is not Kohler. Can you please shed some light on how to remove that sleeve and change the seat.
THanks for your help.
Old 12-13-2009, 09:23 PM   #4
I'd really need to see it. Can you post pictures?
Old 12-14-2009, 06:38 AM   #5
I cannot post the picture as my problem is that I cannot get it out.
Old 12-14-2009, 01:02 PM   #6
If you post even just a picture of the valve itself, someone may recognize it and be able to give instructions from there...
Old 12-15-2009, 07:48 AM   #7
Sounds like a lot of aggravation and trouble with something that old.
Shut the water off and install a new faucet for about 50 bucks.
With all the diy stuff out today you probably won't even have to solder anything.
SULTINI is offline   Reply With Quote
Old 01-11-2010, 07:58 PM   #8
Just removed it. It is similar to 1Z-6H (only one available at home depot). Is it OK to put it in cold side? Now how to replace the new one because the old one just came off with the stem. Please advise.
Thanks in advance.
Shower leaking need to re tile Ineedhelp2009 Flooring 199 02-23-2010 05:46 PM
Shower Faucet Leaking NightOfDiscovery Plumbing 2 08-17-2009 10:58 PM
Shower floor leaking...help! slloyd Plumbing 5 06-13-2009 01:34 PM
Weird shower head leaking problem shawnst Plumbing 5 12-25-2008 11:23 AM
