Leaking Shower Riser Union - Clawfoot - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-12-2012, 11:05 PM   #1
leaking shower riser union - clawfoot
hi all,
i've installed a new strom plumbing faucet and shower enclosure on my clawfoot tub.
everything is perfect except a leak at the double female union connector that the two riser pipes thread into.
the pipes have a little rubber washer at the bottom of the threads. i first thought this meant no teflon and had a major gushing leak.
this time i took it apart and applied teflon AND pipe dope.
the leak is now tiny, about a bead every 30 seconds, but still annoying.
i can't figure out a way to tighten the pipes into the union more than hand tight. i've seen a "pipe strap" but don't own one. i've tried vice grips padded with pieces of leather. i have a strong grip but can't budge it past hand tight. they seem to lock themselves in.
any suggestions on how to deal with this would be appreciated.
thanks!
wombosi is offline   Reply With Quote
Old 07-13-2012, 10:50 AM   #2
Rewards Points: 330
I use Teflon tape and pipe dope
plumberinlaw is offline   Reply With Quote
Black Pipe Union (1-1/2") leaking g-dub Plumbing 3 06-27-2010 09:39 PM
leaking shower valve - fixed? wombosi Plumbing 0 06-22-2010 06:03 PM
shower faucet valve leaking throne7 General DIY Discussions 6 03-13-2010 07:31 AM
Need Help With Clawfoot Shower Curtain Rods. Pawn3d Plumbing 4 11-21-2009 09:04 AM
Water heater hot outlet union leaking dog193 Plumbing 4 01-10-2008 10:07 AM
