Old 08-04-2011, 12:56 AM   #1
leaking shower pipe ideas
I used an old fitting on my shower to find out it leaks... alot under pressure. sprays i should say. So here is my idea. rather than cutting a hole and ripping out the pipe and replacing it im thinking.... Use copper epoxy i bought from lowes. And putting a rubber boot over that with a hose clamp. Think it would work. Thanks for your answers.
joshpg is offline   Reply With Quote
Old 08-04-2011, 01:01 AM   #2
Crap crap crapity crap! fix it right
plumberinlaw is offline   Reply With Quote
Old 08-04-2011, 01:04 AM   #3
do you not think it will hold? what if i sweat it first its on of those pivot pieces its leaking from the seam
Old 08-04-2011, 06:47 AM   #4
Super Moderator
Why not fix it right?
What will you save by rigging it up?
What will it cost to fix it right?
What will it cost in damage if your rig fails?
standup shower leaking after plunging ryanh Plumbing 0 01-22-2011 11:19 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Shower floor leaking...help! slloyd Plumbing 5 06-13-2009 02:34 PM
Leaking Shower Faucet sprtnfan Plumbing 2 12-20-2008 12:08 PM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 09:53 PM
