Old 05-12-2008, 06:58 PM   #1
Leaking Shower Head
Howdy!
I recently finished showering and turned off both handles to the hot and cold water. Only I discovered that the hot water was still leaking. the handle is closed, but water still leaks out. I also noticed some pink rubber pieces when i disconnected the hose. Their doesnt appear to be leaks, i do not see water on the ceiling downstairs. What can cause this? Please help.
globetraveler is offline   Reply With Quote
Old 05-12-2008, 07:18 PM   #2
General Contractor
MacRoadie's Avatar
Leaking Shower Head
It sounds like the valve seat is leaking on the hot side of the mixer valve. It's allowing water to bypass the valve when in the closed position. That red rubber is likely what's left of the washer on the end of the valve stem that compresses against the seat to cut off the flow of water.
MacRoadie is offline   Reply With Quote
Old 05-12-2008, 07:31 PM   #3
Leaking Shower Head
MacRoadie,
Is the valve seat on the hot side located under the handle assembly or more where they connect further back (behind tile wall)
Globetraveler
Old 05-12-2008, 07:39 PM   #4
General Contractor
MacRoadie's Avatar
Leaking Shower Head
It is way back behind the wall. If you envision the valve stem as kind of like an "axle" (for lack of a better term), the handle attaches to one end, and the washer in question is located at the opposite end. Here is a website that shows a pretty good sequence of photos and descriptions of the repair:
http://oldhomeblog.blogspot.com/2007...et-repair.html
Old 05-14-2008, 08:06 PM   #5
Leaking Shower Head
MacRoadie,
Thank you very much. your information was invaluable and the problem was fixed.
very low shower head flow rickard681 Plumbing 7 10-08-2008 07:43 AM
Shower head standard Demochick Plumbing 6 02-29-2008 03:00 PM
No flow to shower head; toilet runs constantly kathleentsy Plumbing 7 05-17-2007 10:05 AM
Stuck shower head stealthxcat Plumbing 1 05-08-2007 10:19 PM
Shower Head Draining pinfordend Plumbing 2 05-04-2006 07:30 AM
