Leaking Shower Head - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-15-2011, 08:27 AM   #1
leaking shower head
i have recently installed a new tub and shower. we hooked up the faucets and shower head before we had the water heater installed. we are using pex so we had the hot water capped off. at the time when just the cold water was hooked up to it it did not leak. after hooking up the hot water whenever we turn on the water water starts to come out of the shower head like like you partially pulled up the diverter. i have a brand new tub and shower system (shower head, faucet and hot cold knob) and no its not leaking from the threads.
Any answers are greatly appreciated!
kerio is offline   Reply With Quote
Old 10-15-2011, 10:16 AM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Did you use pex for ANY PART of the piping from the valve to the tub spout?
Journeyman Plumber
Old 10-16-2011, 01:50 PM   #3
leaking shower head
yes we did. we used it for everything.
Old 10-16-2011, 02:02 PM   #4
AlbacoreShuffle's Avatar
Thats the problem.
You need to change out the plumbing to the spout to copper.
Pex restricts the flow just enough to cause back pressure to flow to the shower head.
AlbacoreShuffle is offline   Reply With Quote
Old 10-17-2011, 08:26 PM   #5
Makes sense. Thank You!!!!!!!!!!
Threaded shower head connection too close to ceiling anygren Plumbing 6 10-11-2010 02:41 PM
My shower head leaks when tub faucet is running? Walter Sobchak Plumbing 4 05-24-2010 09:13 AM
Handheld shower in addition to fixed head OnTheGo Plumbing 4 03-25-2010 12:31 AM
Shower Faucet Leaking NightOfDiscovery Plumbing 2 08-17-2009 11:58 PM
Shower floor leaking...help! slloyd Plumbing 5 06-13-2009 02:34 PM
