Old 06-16-2009, 01:54 AM   #1
leaking shower gooseneck
I believe my shower is leaking wher the goose neck threads into the plumbing behind the wall. i have taken the goose neck off and retaped it and threaded back in. Leak is still there, but less. Suggestions? other problems?
thanks.
gator0625 is offline   Reply With Quote
Old 06-16-2009, 07:07 AM   #2
Damaged threads on the pipe, or in the fitting, look in with a flashlight. Worst case, cracked fitting. Damaged threads can usually be gapped with tape and or pipe dope/putty. Cracked fitting will have to be replaced. Easier to access from behind, even if you have to tear out drywall, easier to fix than tile.
Old 06-16-2009, 07:55 AM   #3
RippySkippy's Avatar
As Bill suggests, inspect the threads the best you can...the goose neck will tell you a lot about what's happening in the wall. I'd take your fitting out again; clean, re-tape AND apply some plumbing pipe dope in addition to the tape. When you install it, protect the pipe and snug it up well.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 06-16-2009, 08:32 AM   #4
Joe F's Avatar
Might want to try a new goose neck, the threads might be worn or corroded.
If you don't stand behind our troops, please feel free to stand in front of them.
Joe F is offline   Reply With Quote
Old 06-16-2009, 10:06 AM   #5
Showerhead arm pipe is usually very thin. I am guessing that there is a crack near the top of the threads on the arm.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Shower floor leaking...help! slloyd Plumbing 5 06-13-2009 02:34 PM
Weird shower head leaking problem shawnst Plumbing 5 12-25-2008 12:23 PM
Leaking Shower Faucet sprtnfan Plumbing 2 12-20-2008 12:08 PM
Tiled seat in Shower leaking? pinkcenturygirl Plumbing 3 11-17-2008 05:49 PM
leaking 7 yr old shower blitzndyna Remodeling 3 05-18-2008 09:15 PM
