Old 01-13-2013, 10:57 AM   #16
Leaking Shower Faucet
You did shut the water off and relieve the pressure before removing the stem, right?
Old 01-13-2013, 05:32 PM   #17
I've got the special sockets for the valve stem. I haven't removed any stems yet. Why does the entire stem need to be replaced? I thought I could put on new washers and valve packing and be done with it.
JeremyRay is offline   Reply With Quote
Old 01-13-2013, 06:20 PM   #18
Lightfoot's Avatar
You may not have to replace the entire stem. You can rebuild them as long as they aren't worn or damaged. I keep rebuild parts on hand for mine because i have so many, but i would also recommend changing the stem seats while they are out (use plumber's grease on them also). If they are original, they likely need it. It takes about a minute to do each one, and it only costs a couple of bucks. I learned the hard way it's better to do it now than have to pull'em again later.
Lightfoot is online now   Reply With Quote
Old 01-13-2013, 09:05 PM   #19
O.K. I'm pouring WD40 on the remaining two handles. Maybe in a week they'll loosen up.
Old 01-15-2013, 07:05 AM   #20
Originally Posted by joecaption View Post
I'm going to have to get one of these to pull the last two handles. Will it definitely definitely work?
Is this the same thing - Link
It's not going to slip over the end of the handle like the non-clamping tool I've got?
Old 01-15-2013, 07:24 AM   #21
Lightfoot's Avatar
I don't think so. The pointed shaft part of that tool would need to push against the top of the stem, not the handle. I guess you could thread a longer bolt in the stem which will stick out further. I'm still not sure it would work, but it might. Have you tried heating them?
Old 01-15-2013, 08:03 PM   #22
Lightfoot - What would you recommend heating them with?
jagans - No such thing as a dumb question, right?
The Chinese stuff is hit-and-miss. I bought a pair of cable pliers that broke the first time I used them. I've bought tools that are more than adequate for my needs, but wouldn't hold up under professional use. I've bought hobby items that were excellent, at a few time less the cost of the American or European counterpart, which I couldn't have afforded. The trick is to get on the internet and see what experiences others are having. Or be rich and always buy the best quality American or European stuff, but that strategy isn't going to work for most Americans anymore.
Old 01-18-2013, 12:56 AM   #23
Hey, where'd ya go?
Old 01-23-2013, 11:34 PM   #24
I think you'll need a good plumber to fix the issue.
Cheap sewer service Ozone Park
JonieAnderson is offline   Reply With Quote
Garden Hose faucet leaking (replacing) greentrees Landscaping & Lawn Care 9 05-13-2012 04:06 AM
Need help: Broken stem in Moen shower faucet valve cartridge Learning Lots Plumbing 9 05-04-2012 11:56 AM
picking a shower faucet vote4Pedro Plumbing 7 05-27-2011 09:56 PM
Bathroom Sink Faucet Leaking sgold33 Plumbing 1 01-17-2011 07:16 PM
Bathtub faucet runs when shower is on aggyanna Plumbing 2 12-21-2009 10:21 AM
