Leaking Shower Drain - Screw Gasket - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-06-2011, 09:53 AM   #16
Rewards Points: 2,512
Have you tried contacting Oatey for a replacemet?
http://www.oatey.com/Channel/Shared/...ng+Gasket.html
hammerlane is offline   Reply With Quote
Old 12-06-2011, 10:02 AM   #17
I don't think mine is the standard "no-calking" gasket from Oatey. The original gasket seems to be threaded on both the inside and outside (maybe a result of being in the drain for 10 years?) and is also thicker. The new ones all seem to have a compression ring (far right of image) that expands the gasket. Mine has no compression/calking ring.
eclipsis is offline   Reply With Quote
Old 12-06-2011, 06:49 PM   #18
Rewards Points: 582
Originally Posted by eclipsis View Post
Thanks for the help!
Yeah, I have lots of cleanup to do on this pipe. It seems like it was almost melted off rather than cut. Would you recommend anything on the gasket (silicone/putty) or will it seal by itself? Will let you know how things go.
they have inside pipe cutters..i think 12-15 dollars..
Old 12-06-2011, 07:52 PM   #19
Just to confirm, there is a difference between the gaskets correct? Mine seems to be larger and seal by its size. The new ones seem to have a "calking ring" that screws in on top of the gasket to flatten it out. This won't work and I'll have to find the old style with no ring.
Old 12-06-2011, 09:09 PM   #20
DIY staff
Rewards Points: 7,174
Wrong gasket--sorry---You may have to make some calls --that is a compression gasket--you need a barbed gasket----
That pipe was hacked off with a dull saws all blade---you need to trim that back and clean it up--
You can still get those gaskets as I did get one a few months back ---plumber poured in lead instead of using the gasket---failure--
Old 12-06-2011, 09:25 PM   #21
Any suggestions on where to get one? Seems Lowes and Home Depot all have the compression ones with the ring.
Old 12-06-2011, 09:45 PM   #22
Rewards Points: 582
was the old one leaking....I thougth we got one from ace hardware..
Old 12-06-2011, 09:53 PM   #23
Rewards Points: 582
hey guy go to ebay type in shower drain gaskets....fernco makes a universial for your shower...says it for the ones with build in strainer.....
Old 12-07-2011, 06:07 AM   #24
DIY staff
Depot stocks those in the Fernco display---
Old 12-07-2011, 08:10 AM   #25
The only one I see on Home Depot's website says its for cast iron
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
Would that work in my case?
Old 12-07-2011, 04:21 PM   #26
Rewards Points: 582
I believe fernco #psd-200 should work
Old 12-07-2011, 10:14 PM   #27
Any idea what the difference is from PSD-210. I found a PSD-210 local, but will have to get the PSD-200 online. I'm not really in a hurry, so if the 200 is preferred, I can wait for online delivery.
Old 12-07-2011, 10:21 PM   #28
It seems that 210 is "For Mustee or Owens Corning 1 piece molded shower base" while 200 is "For American brass and Aluminum, Armstrong, Casper, Garvin, Intercon and Kohler".
Looks like online order it is. By the way, I found them on Amazon for $3.80 + $3.80 shipping.
Old 12-07-2011, 10:33 PM   #29
Rewards Points: 582
awesome we bet it again yes the 200 seems to be the one it says casper which is your gasket....good job.. ben
Old 12-21-2011, 09:28 PM   #30
Finally received the gasket from Amazon and it's not the right one. Easily fits around the pipe and installed simply by hand. It doesn't have enough width to properly compress against the drain body and the watery freely runs between the outside of the gasket and the drain body.
I guess only option now is to try the Wing Tite drain or tear into the ceiling below to access the bottom of the drain?
Has anyone used the Wing Tite before? I'm not sure I understand how I cut out the old drain with only top access... what happens to the nut on the bottom? It just falls down the pipe?
Looking like I may just have to call a plumber, although they may have to cut into the ceiling anyway...
Centering existing drain to shower insert? Squeakyhinge Plumbing 5 04-07-2011 08:27 AM
Replacing putty in shower drain, question about drain construction scottyv81 Plumbing 4 03-28-2011 08:43 PM
Shower drain phymonkey Plumbing 0 10-04-2010 03:19 PM
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 03:25 AM
First shower install, drain help please! tigerbalm2424 Plumbing 6 01-16-2008 06:44 AM
