Leaking Rohl Pullout Kitchen Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-01-2012, 10:16 PM   #1
Rewards Points: 22
Leaking Rohl pullout kitchen faucet
My Rohl kitchen faucet is about 8 years old but is now leaking. I have no paperwork on it. I need to locate instructions on how to disassemble it and replace warn parts etc. Many faucets have some sort of starting point such as an allen screw or something, but this faucet has zero. I checked the Rohl website and the faucet is there but no diagrams to help. any other places to look before I spend the big bucks for a plumber?
Ronnie1a is offline   Reply With Quote
Old 06-02-2012, 10:42 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 594
Ayuh,... Got a Picture of it,..??
Old 06-02-2012, 03:49 PM   #3
sacramento plumber
wctekkk's Avatar
Location: born and raised in San mateo ca. living in Sacramento Ca for 3 years now.
Rewards Points: 77
http://www.rohlhome.com/pdf/483.pdf
wctekkk is offline   Reply With Quote
The Following 2 Users Say Thank You to wctekkk For This Useful Post:
Ronnie1a (06-03-2012), VIPlumber (06-02-2012)
Old 06-03-2012, 09:52 AM   #4
Rewards Points: 22
Perfect-thanks so much
Old 03-22-2016, 11:01 PM   #5
Rewards Points: 4
Re: Leaking Rohl pullout kitchen faucet
Hi Ronnie = in same boat with my Rohl Any one know how to remove the cartridge from fixture? Pic attached.
bmchugh1 is offline   Reply With Quote
Old 03-23-2016, 07:43 AM   #6
Rewards Points: 582
after looking at instructions..have to remove cartridge clamp nut...looks like the part that has the hole in it....is there another hole on the otherside of that brass washer on top of cartridge...if so have to unscrew it ..
Old 03-23-2016, 10:36 AM   #7
Rewards Points: 4
Thanks for help. There is another symetrical hole on the other side. However, after inspection it appears that portion (which looks like a brass ring holding the cartridge down) is actually connected (or a least looks to be connected) to main piece. I have turned the main piece as hard as a can and can't seem to get it to turn. Not even sure it does turn. Those holes have to be there for a reason. I wonder if there is key or something?
The Following User Says Thank You to bmchugh1 For This Useful Post:
ben's plumbing (03-23-2016)
Old 03-23-2016, 05:19 PM   #8
Rewards Points: 582
it really looks as though that ring has to come off to remove cartridge...maybe stick needle nose pliers in holes and try to turn..remember righty tighty lefty lucy...
Delta kitchen faucet is leaking under the sink grave20 Plumbing 2 04-01-2012 02:00 PM
Leaking Delta Victorian model 2256 kitchen faucet deputiej Plumbing 6 01-11-2012 08:26 PM
Kitchen faucet splinter2 Plumbing 1 01-13-2011 12:50 PM
Leaking kitchen faucet!!! And disposal question... Beth777 Plumbing 9 08-30-2008 07:57 PM
Question about a kitchen faucet skwpt Plumbing 10 10-11-2007 07:54 PM
