#1 |
Leaking Rheem 60 gal Electric Hot Water Heater
I have a question for anyone out there who can help me solve a water heater problem I am now having.
Please ![]() My water heater appears to be leaking, I believe it is leaking from the bottom of the heater itself because I cannot see or feel any moisture from any of the pipes. Can someone who knows about water heaters tell me just where the leak could possibly be coming from? FYI: I leave in a doublewide mobile home, if I had to purchase a new water heater would the type of water heater make a difference between a mobile home and a conventional home? Correction: I have a 40 gallon electric Rheem water heater model 71-408B Last edited by aklkuno1; 10-22-2008 at 02:58 PM. Reason: entered wrong gallons amount |
#2 |
Water heaters usually do leak from the bottom. They just rust out. Often, the leak will extinguish the pilot, and you don't have hot water anymore.
Unless the water is coming from the pressure release / safety valve, then you need to replace the water heater. As for the type, I cannot give you any advice on whether it would be different for a mobil home.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 | |
My License Ain't 4 Sale..
Leaking Rheem 60 gal Electric Hot Water HeaterQuote:
#4 |
If it has been around for a while you probably need a new one. They have life span of about 10 years or so depending on the type of water.
When you get a new one check to see if there are any tax credits for the higher efficiency ones. Many times they are more money but can save you energy costs and with the tax credit can be a nice deal.
My idea of a perfect day: No where to go and all day to get there. |
| Display Modes | |
| Electric Water Heater | GTSRider | Plumbing | 31 | 12-07-2008 12:30 PM |
| Electric Water Heater Problem | mw2727 | Plumbing | 4 | 08-21-2008 02:51 PM |
| (Water Heater MYSTERY) Hot water out from dead tank with cold water in it? | Inayity | Plumbing | 6 | 07-14-2008 09:36 PM |
| Electric tankless hot water heater | former33t | Plumbing | 2 | 02-28-2008 12:40 PM |
| Periodic release from (I think) the T&P valve on the water heater | alexz | Plumbing | 3 | 08-15-2006 11:31 AM |
