Leaking Rad Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-17-2010, 03:58 AM   #1
leaking rad valve
Hi,
I have water leaking from my bathroom radiator valve this morning, just dripping but constant. It's a straight rad valve and from catalogues looks like a Hudson Reed HT 320 - it may be a look alike though. The water is coming from under the flow regulator handle, the connections to the copper feed and radiator itself are fine. I guessed that I could remove the the regulator handle and perhaps tighten the nut underneath but so far can't get the handle off. Anyone know how it's fixed?
If the rad valve is unfixable then I think I have a bit of a job on because one of the isolation valves to the rad isn't working and looks like a real pig to get to and replace. (Bath out and oak and ply floor up to get to the lower compression joint)
Steve
Grainoftruth is offline   Reply With Quote
Old 12-17-2010, 06:51 AM   #2
Most valves have a packing nut on top. It has a washer or packing material inside that compresses around the valve shaft, Tighten the nut a bit, Usually only a fraction of a turn is needed to tighten things up. It should be loose enough that you can still turn the valve, but have friction from the packing material.
Old 12-17-2010, 01:06 PM   #3
Thanks Just Bill,
I did get the valve apart but there was no packing nut, just a circlip so no adjustment. Finished the job about an hour ago - both rad valves and both isolating valves. Just got to repair my floor now.
Steve
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 05:19 PM
ball valve leaking bwall Plumbing 10 12-31-2012 08:25 PM
Leaking shut off valve, am I that inept??? ChrisDIY Plumbing 12 07-28-2012 08:52 PM
leaking pressure relief valve on heating water boiler benjamintr HVAC 13 01-29-2011 06:32 AM
leaking shower valve - fixed? wombosi Plumbing 0 06-22-2010 06:03 PM
