Leaking Presure Valve On Furnace - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-03-2009, 03:49 AM   #1
Rewards Points: 115
Leaking Presure valve on furnace
I recently noticed this valve dripping, it's off of a line coming out of the furnace in a "L" shape.
Is it safe just to turn the heat off & replace this valve?
Thanks in advanced!
Carloscda is offline   Reply With Quote
Old 01-03-2009, 07:23 AM   #2
Whatamess
If it is the stem packing just tighten the nut some or try back setting the handle. Is it a humidifier line, boiler or what. Some pictures would help.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 01-03-2009, 10:09 AM   #3
could be a worn pv valve or to much pressure in the system .look at the label on the valve it should say 35 psi ,then look at the gauge on the boiler . could be your expansion tank if hot water
metx is offline   Reply With Quote
Old 01-03-2009, 01:18 PM   #4
Rewards Points: 115
Here are the pictures..
Old 01-05-2009, 05:01 PM   #5
Rewards Points: 115
This is the valve I was referring to.
Old 01-06-2009, 11:41 AM   #6
Master General ReEngineer
Bondo's Avatar
Rewards Points: 334
Ayuh,...
That's the Safety Blow-off Valve....
Replace it...
Old 01-06-2009, 02:52 PM   #7
Registered User
Termite's Avatar
Of course you'll need to turn the unit off and let it cool down to release pressure first. Don't want you getting burned.
It's called a T&P (temp and pressure) blowoff valve. They're $5.
Old 02-12-2009, 02:27 PM   #8
I picked up the replacement part for this from Home Depot ($20)
Do I have to drain the system, if so how?
Carloscda40 is offline   Reply With Quote
ball valve leaking bwall Plumbing 10 12-31-2012 08:25 PM
leaking pressure relief valve on heating water boiler benjamintr HVAC 13 01-29-2011 06:32 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
