-   -   Leaking Presure valve on furnace (http://www.diychatroom.com/f7/leaking-presure-valve-furnace-34968/)
Carloscda 01-03-2009 02:49 AM
I recently noticed this valve dripping, it's off of a line coming out of the furnace in a "L" shape.
Is it safe just to turn the heat off & replace this valve?
Thanks in advanced!
http://C:%5CDocuments%20and%20Settin...2009%2001%2003
TazinCR 01-03-2009 06:23 AM
If it is the stem packing just tighten the nut some or try back setting the handle. Is it a humidifier line, boiler or what. Some pictures would help.
metx 01-03-2009 09:09 AM
could be a worn pv valve or to much pressure in the system .look at the label on the valve it should say 35 psi ,then look at the gauge on the boiler . could be your expansion tank if hot water
Carloscda 01-03-2009 12:18 PM
Here are the pictures..
http://i540.photobucket.com/albums/g...IMG_0770-1.jpg
http://i540.photobucket.com/albums/g...IMG_0773-1.jpg
http://s540.photobucket.com/albums/g...on=tageditmany
Carloscda 01-05-2009 04:01 PM
This is the valve I was referring to.
Bondo 01-06-2009 10:41 AM
Ayuh,...
That's the Safety Blow-off Valve....
Replace it...
Termite 01-06-2009 01:52 PM
Of course you'll need to turn the unit off and let it cool down to release pressure first. Don't want you getting burned.
It's called a T&P (temp and pressure) blowoff valve. They're $5.
Carloscda40 02-12-2009 01:27 PM
I picked up the replacement part for this from Home Depot ($20)
Do I have to drain the system, if so how?
