Leaking Pressure Relief Valve Of Boiler - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-02-2010, 12:03 AM   #1
Leaking Pressure Relief Valve of Boiler
Hello,
I have a residential Utica Boiler (looks like it was installed in 1983) that is leaking a decent amount of water through the pressure relief valve when running. Today I replaced the pressure relief valve with a new one (30 psi), and replaced the expansion tank with the exact same model (Watts ET-15) since the old one was completely waterlogged. I bled the system, turned the auto-feeder back down (I guess this reduces inlet pressure coming from the municipal source?), heard the expansion tank fill up, then started her up, only to see more water dripping from the relief valve. The pressure gauge looks like it hits 30 psi when running. I am getting heat through the radiators, but don't like the fact that the boiler is leaking so much water.
I'm at the of end of what I can handle / replace myself. My questions are:
(1) Does anyone have any other trouble-shooting suggestions that I can try, or should I just call a plumber/boiler technician?
(2) Does this sound like something that a technician can address, or is my boiler at the end of its life? What might the technician do to service this?
(3) Finaly, is this a safety issue, or can I continue to operate the boiler even if it's leaking a fair amount of water?
Thanks for any help and suggestions.
Regards,
Rob
Leaking Pressure Relief Valve of Boiler-boiler-1.jpg   Leaking Pressure Relief Valve of Boiler-boiler-2.jpg   Leaking Pressure Relief Valve of Boiler-boiler-3.jpg
rob07030 is offline   Reply With Quote
Old 11-02-2010, 07:20 AM   #2
Rewards Points: 1,216
Is there a pressure/ temperature gauge on the boiler? If so what is it reading.
COLDIRON is offline   Reply With Quote
Old 11-02-2010, 08:11 AM   #3
Rewards Points: 1,440
Is there a shutoff valve (not just an autofill valve) for the fresh water feed to the boiler? Turn this off but keep observing to see if water is still continually released from the relief valve.
Is your domestic hot water from a tankless heat exchanger on the boiler? Water heating coils can spring a leak and then the boiler gets too much water in it all the time. The boiler normally runs at a somewhat lower pressure than the water supply.
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 05:19 PM
pressure relief valve matt426 Plumbing 0 10-07-2010 09:50 PM
Hydronic boiler pressure question. RickInMissouri HVAC 1 01-23-2010 05:57 AM
Resource for understanding gas valve? darsunt HVAC 19 02-04-2009 12:08 AM
Help-Pressure Relief Valve running water constantly janhuggies Plumbing 3 01-17-2009 06:15 PM
