Old 10-26-2007, 03:39 PM   #1
leaking pipes
Hi, I need some advice. My shower head started leaking about 2 months ago. We replaced the shower head but it still leaked. And the shower knobs, but it continued to leak. After a couple of weeks it really started leaking heavily. Well, I inadvertly turned the knob so much that it would not turnoff the water, So, we kind of turn it off with a contraption that turns it off and on. WEll we do not use the shower anymore but know the water is leaking behind the shower wall. WE have another problem because now there is mold and fungus growing outside the shower wall facing the backYARD. WE need serious help
tina cosio is offline   Reply With Quote
Old 10-26-2007, 09:22 PM   #2
leaking pipes
I agree. Call a licensed plumber.
scrapiron is offline   Reply With Quote
Old 10-26-2007, 09:39 PM   #3
Long-Time DIYer
Mike Swearingen's Avatar
leaking pipes
Tina,
Shower heads and knobs don't actually leak, the control valves at the faucet body leak (depending upon the type...it could be worn washers and o-rings, or seats-and-springs, or a cartridge).
Based on your post, I agree that you need to call a licensed plumber.
Good luck!
MIke
Mike Swearingen is offline   Reply With Quote
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 08:22 AM
water leaking from pressure balance spool lauralyn1 Plumbing 16 08-13-2007 05:50 PM
Supposedly 'new' roof is leaking beejay Roofing 3 03-06-2007 11:55 AM
leaking bathtub mikeynholly Plumbing 1 02-11-2007 02:50 PM
Installation of new pipes on Water main... NJE Plumbing 3 02-05-2007 01:06 PM
