Leaking Pipe Under Upstairs Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-23-2011, 12:56 PM   #1
leaking pipe under upstairs toilet
I had a plumber diagnose my leaking toilet and he assured me that i had a haircrack in my toilet. After installing new toilet, it still had a leak. Cut a hole in the ceiling and removed toilet. Poured water down drain and it still had water dripping around the elbow.Could this be a leak at the joint or where.Is it a possible easy fix
Last edited by mike49; 06-23-2011 at 03:11 PM. Reason: To get more clarity on this problem
mike49 is offline   Reply With Quote
Old 06-23-2011, 11:03 PM   #2
sir, read my post where i replied to incopetent builder thread later on today than yours. if it is leaking out when you pour water in the drain it is definately not a wax seal problem but a glue or hole in pipe problem. they make a sealer that is clear and unlike silicone you can use it on wet locations. if it is a joint not sealed you rub this stuff around the place where the hub and pipe meet and fix your problem. i can't think of the name of it right know but i get it at a local supply house and the big chain stores don't carry it. reply to me if your sure it's leaking around the fitting and i will get the name of it tomorrow as i keep a tube in my truck. a roofer turned me on to it and it can be a magic wand to a plumber on a service call. thanks, budro
buddy builder is offline   Reply With Quote
Toilet leaking after moving GBunny Plumbing 2 04-28-2011 05:49 PM
Toilet leaking at the base on floor John24689 Plumbing 4 10-19-2009 09:03 AM
Leaking kitchen sink drain pipe zasior Plumbing 10 01-11-2009 08:22 PM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 09:53 PM
