Leaking Pipe Under Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-20-2007, 01:16 PM   #1
Leaking pipe under toilet
We have noticed that in our basement the pipe that where the pipe that runs from our toilet connects to the rest of our pipes there is a very slow drip. And in the bathroom there is a very very small amount of water that seeps out from under the toilet. We have changed the wax ring on this toilet at least 4 times, each time thinking that we might have done it wrong the last time. And we even called a plumber and he said the problem with the pipe in the basement is that the person who redid our plumbing didn't glue the two pipes together. He said he fixed it, but there is still a slow drip. It is MUCH slower than it was before, but it is still there, and there is still the seepage around the toilet. We have looked at the toilet itself and have not noticed any cracking where it would be leaking, what could this be?
aprildawn is offline   Reply With Quote
Old 01-20-2007, 01:28 PM   #2
jproffer's Avatar
Rewards Points: 702
Get a wax free gasket...less chance for mistakes. Fluidmaster makes them and they're available at Lowes among other places.
As far as the pipe in the basement, I would guess the fitting joint is fine and the water coming out upstairs is following the pipe down and dripping off when it gets to a "drip line", where it would have to go back up (against gravity), such as where the fitting and pipe meet.
jproffer is offline   Reply With Quote
Old 01-20-2007, 07:53 PM   #3
Stick with the real wax. When you pull the toilet, flip it over on it's side and look up under the trap carefully. You are looking for cracks or a defect in the china. Seen a few in my career. Sometimes water in the bowl will drain out of said defect, proving it is there. Does the water level in the bowl stay at one level, or does it slowly drop?
gitnerdun is offline   Reply With Quote
Old 01-21-2007, 09:04 AM   #4
Journeyman Plumber
Ron The Plumber's Avatar
Did you ever think the leak seen on the floor might be coming from the tank, tank to bowl could be leaking and rolling down to the floor.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 01-21-2007, 05:32 PM   #5
From what I can tell the water level in the bowl stays the same. We didn't think to look up into the toilet when we pull it up, however. We will try that.. Guess we'll change the wax ring again....
Pipe knocking when toilet flushed guykovera Plumbing 5 09-27-2008 09:17 PM
Leaking waste pipe guvlin444 Plumbing 5 09-30-2006 02:36 PM
Of course something else had to go wrong - leaking pipe. J187 Plumbing 7 07-30-2006 08:56 PM
Toilet; Cistern to Toilet pipe ( Complete Novice) broke1973 Plumbing 1 07-15-2005 09:34 AM
Leaking Pipe STEPBK2 Plumbing 1 12-06-2004 01:57 PM
