Leaking Pipe - Cost Estimate? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-18-2012, 12:01 PM   #1
leaking pipe - cost estimate?
Hey guys,
I have a small in diameter (see attached pic) leaking pipe (1 drip per 2 minutes) on the backside of the building above garages. The plumber gave me an estimate of 200$ and explained he will have to have an access to 2 units, drain water from the units and then perform the repair.
I live in CA, does this seem like a reasonable price?
Thank you,
Edita
edavt04@gmail.c is offline   Reply With Quote
Old 07-18-2012, 01:26 PM   #2
DIY staff
Rewards Points: 7,174
Actually sounds cheap----If the worker is competent--I would go for it---
Old 07-18-2012, 09:30 PM   #3
Rewards Points: 582
Originally Posted by edavt04@gmail.c View Post
Hey guys,
Thank you,
Edita
that don't sound cheap it is...make sure thats a firm price..he may start there and finish at 500.00 to 600.00
The Following User Says Thank You to ben's plumbing For This Useful Post:
oh'mike (07-19-2012)
Old 07-20-2012, 06:20 AM   #4
Rewards Points: 1,216
I thought the price is reasonable for the location of the leak and the up and down factor.
COLDIRON is offline   Reply With Quote
Could you give advice on a leaking lead pipe supply line? markcal02 Plumbing 3 10-18-2011 08:03 AM
Main hot water pipe leaking under slab tiredofleaks Plumbing 9 09-12-2011 02:45 PM
Means/Richardson construction cost estimate lookup help please tomseeley Building & Construction 1 03-21-2011 01:36 PM
Leaking vent pipe? emylime Roofing/Siding 12 04-28-2010 01:47 PM
