Leaking Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-01-2010, 05:05 PM   #1
Question
Leaking pipe
This just started leaking last week, each night the bowl is filled with clean water. I tried to tighten the 2 metal screws however that did not help. I am unable to see if there is a crack, but I think it may be that the rubber piece making a tight fit is old and worn out. What should I do?
Pic:http://skitch.com/kopac07/nh134/dsc00024.jpg
kopac07 is offline   Reply With Quote
Old 04-02-2010, 12:14 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
I really couldn't tell where it is leaking from the photo, but if it is at that neoprene rubber coupling (aka a Fernco coupling) and tightening the ss clamps doesn't work, just replace it.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 04-02-2010, 10:04 PM   #3
Household Handyman
Rewards Points: 1,408
I would definitely remove the "Fernco" type coupling, clean the surfaces it seals against, and place a new coupling on. There should be a gap, not very much between the two pipes the "Fernco" is on and the coupling can be worked through this gap IF you cannot move the piping to gain more room. The piping needs to be in good alignment for the coupling to work properly. David
Water leaking through copper pipe. willowgirl Plumbing 10 01-17-2010 06:29 PM
Pipe just started leaking gruntman Plumbing 7 08-20-2009 11:37 PM
Leaking kitchen sink drain pipe zasior Plumbing 10 01-11-2009 08:22 PM
Water leaking into septic pipe below toilet Gramps Plumbing 1 09-14-2008 10:54 PM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 09:53 PM
