Leaking P-trap After Replacing - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-27-2011, 03:13 PM   #16
Developer by Day
Send a message via AIM to KevinACrider
I picked up a small tube of the PTFE Plumbers Paste and filled the open-wedged piece with it. I also applied a little to the threads, as recommended above, and it went much smoother. The paste on the threads made the nut tighten up much much easier than it previously did and the liberal amount of paste I put in the wedge filled the void where it was leaking. I ran hot water through the drain for about 10 minutes and not a single leak!
Thank you so much for the replies! I've been a member here for several years but it was actually a google search that brought me to this thread. Hopefully future searchers will benefit from the newly added replies.
KevinACrider is offline   Reply With Quote
The Following User Says Thank You to KevinACrider For This Useful Post:
TheEplumber (11-27-2011)
Old 10-10-2015, 09:24 AM   #17
Rewards Points: 2
Originally Posted by ron schenker View Post
I'm not a plumber butt, the "black pvc" is actually "ABS" and should work ok if you threaded it on properly(no cross threads)
I'm curious as to why you didn't replace the old P-trap with an original type pvc one.
You could try to wrap some teflon tape around the threads for a better seal
I'm sure a plumber will chime in soon
He said "Plumber Butt"..
jacksonmc642 is offline   Reply With Quote
Old 04-07-2016, 12:44 PM   #18
hello kitty's Avatar
Re: leaking p-trap after replacing
For diggitydog: Thanks for the help. Looked a while on the internet before I found your solution. It's aces! FYI Task was to reattach the trap after cleaning. My wedge had a small spur (thin piece of plastic) that the plumber failed to remove when it was installed originally. I recall he had a problem getting a seal. I removed that with my fingernail, cleaned off the other sealant I had tried, used your recommendation (I found Real-Tuff PTFE Paste Thread Sealant at Home Depot) and voila! It was sealed. (For those getting here wanting to know if sealant is absolutely necessary, all I can say is that the plumber used it and I used it - and it seals) Thanks again
hello kitty is offline   Reply With Quote
The Following User Says Thank You to hello kitty For This Useful Post:
oh'mike (04-07-2016)
ball valve leaking bwall Plumbing 10 12-31-2012 07:25 PM
Leaking Condenation Trap - Bryant falcon HVAC 9 04-01-2009 06:17 PM
water leaking from pressure balance spool lauralyn1 Plumbing 16 08-13-2007 04:50 PM
Attic A/C Unit Condensate Trap bardad1022 HVAC 3 06-25-2007 07:30 PM
leaking bathtub mikeynholly Plumbing 1 02-11-2007 01:50 PM
