Leaking Old Well Water Feed/pipe Into Basement - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-20-2010, 03:58 PM   #1
leaking old well water feed/pipe into basement
Hi i have a house built in 1919 and we have always had some water in the basement after heavy rain. my wife's great grand parents built the house. the foundation is field stone and whatever they had aruond apparently.
this last bad rain we had, there was a garden hose like leak from a crescent moon shape from the wall. it squirted from the wall at 90* and had some pressure behind it. from what i understand, by talking to the aunt that lives up the street still, the house used to be well water and now its city water.
it looks like someone cut a 3" iron pipe flush with the wall and cemented over it. the pipe is under our back porch steps and it cannot be dug up with out it being a major project. i think with the heavy rain, the whats left of the well fills up, and floods our basement due to it being the path of least resistance.
i was thinking about hammer drilling out the pipe end and just stuffing it and using hydraulic cement or some other product.
any ideas or suggestions?
thanks,
pete
west haven, CT
pyropete125 is offline   Reply With Quote
Old 03-20-2010, 05:32 PM   #2
Rewards Points: 150
There are codes in most states about water well abandonment.
You can get the information from your state or county government. Or, call a local driller.
These codes are to protect the aquifer and should never be taken lightly.
In Michigan the cement or benoite has to be PUMPED, not poured.
The material used is determined by the depth of the bed rock.
Please be a good steward of the Earth.
http://www.drought.state.ct.us/wellresources.htm
Here is some general numbers.
user69544 is offline   Reply With Quote
Old 03-20-2010, 06:10 PM   #3
i have no idea where whatever well is in my yard. the cement that covered the pipe had held for years until now. i just want to stop it from going into my basement. houses here are right next to each other and everybody is on city water.
Old 03-20-2010, 06:49 PM   #4
Rewards Points: 150
Start at the pipe with a metal detector. Sometimes the county will have records.
And sometimes you just can not find them.
First time homeowner from MD - Water Leaking from Ceiling under bathroom j_cross Plumbing 2 02-27-2010 12:37 AM
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 01:17 PM
stop water from leaking into basement? njhomer General DIY Discussions 5 01-26-2009 11:03 AM
Water in the basement - help! jkrodger Building & Construction 6 03-19-2008 04:25 PM
