Leaking Main Drain Clean Out Plug. - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-25-2010, 09:07 PM   #1
Leaking main drain clean out plug.
Every 5 years or so my main drain backs up due to roots in the pipe out to the street sewer line. Just had them cleaned out again.
M y problem is with the drain plug: it's leaking, the reason being that the threads on the plug are too worn/stripped to tighten it properly. This, in turn, seems to be caused by corroded/damaged threads in the old cast iron pipe which seem to be rounded off rather severely. They also seem to have built up quite an accumulation of rust and who-knows-what, essentially closing the size of the opening. (I purchased a new plug of the correct size but it won't even begin to go on due to the closing up of the original pipe hole diameter.
It seems to me that the threads in the clean-out access hole need to be re-tapped. Am I right? Is this possible and, if so, how does one do this?
Any help or alternate suggestions would be much appreciated.
dakornblum is offline   Reply With Quote
Old 10-25-2010, 10:44 PM   #2
http://www.plumbersurplus.com/Prod/D.../59276/Cat/772
you don't have to spend 25 bucks, it's the first pic i found. home depot and lowes will have them for under 10 bucks, take the old one with you to get the correct size
the_man is offline   Reply With Quote
The Following User Says Thank You to the_man For This Useful Post:
dakornblum (10-27-2010)
Old 10-26-2010, 07:20 AM   #3
and before you insert/tighten the expansion plug, fill the nasty iron threads with some plumbers putty.
The Following User Says Thank You to Just Bill For This Useful Post:
Partially blocked main drain? jimithing78 Plumbing 4 05-31-2010 02:29 PM
Water Backing up Though hole in basement dynamis Plumbing 3 06-15-2009 06:11 PM
Main drain water back ups destroyer427 Plumbing 7 04-07-2009 01:58 PM
roots in main drain jerry1967 Plumbing 5 10-28-2008 04:57 PM
PVC drain pipe leaking at joint, 2 part epoxy last? harleysilo Plumbing 3 09-26-2006 01:29 PM
