Old 01-09-2009, 11:41 PM   #1
Default Leaking main drain clean out plug
Our main drain backed up into the basement, so we called Roto Rooter. The guy came out, lugged that big machine down the basement stairs, and attacked the problem. When he removed the clean out plug, he said it probably should be replaced. He said it would only cost an additional $12. After finishing clearing the main drain, he went out to his truck and returned with a new clean out plug. Alas, it was the wrong size, he said. He said ours was 3.5 inch? and all he had was 4 inch? He put the old one back on, said we should be fine, but that we might want to go to Lowes sometime and buy a new one. After he left, I flushed a toilet and discovered leaking from the clean out plug.
The pipe is pvc and the plug is the type with the rubber in the middle and the wing nut on the outside.
My question is should I have them come back out to fix this or should I just take care of it myself? I tried searching for clean out plugs on Lowes and Home Depots' websites and couldn't find anything. I kind of wonder if the fact that it was 7:45 pm and he said he got off at 8:00 had any bearing on this. He also left a mess on the floor and I later noticed in their Yellow Pages ad that they listed "maid-like clean up services." If they do come back out, should I just have to pay for the part itself and not for a service call?
Thanks for any feedback.
bucksone is offline   Reply With Quote
Old 01-10-2009, 09:42 AM   #2
You have a couple options, you can get an adapter for the pipe and have a standard cleanout plug, or go and get a new pipeplug/test plug similar to what you have. As for the mess left on the floor, that is unacceptable, we're not talking saw dust here. That should of been cleaned up, I assumed their maid service is for over-flows or ruptured pipes, not from him/her working on the pipe.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
More On This Topic
How to Install a Drain Plug
How to Install a Drain Plug by Expert Village
Hi, I’m Dean Donnel for expertvillage.com. Now we’re going to install the drain plug. There’s a few things you need to know before you install your drain plug. You can get into trouble if you tighten it and don’t get your threads... Read More »
Hello! My name is Dean and on behalf of expertvillage.com, in this clip we are going to take a look at checking the bottom of your vehicle for oil leaks before we drain the oil as this can help determine if you have an issue before you drain the oil or... Read More »
How to Replace Car Oil Plug
How to Replace Car Oil Plug by Expert Village
Now we are going to take our drain plug and going to put that back in the oil pan. Same thing here, we want to make sure that this plug is tight, so it is not going to leak and is not going to back itself out from the vibration of the car. You don't want... Read More »
Hi this is Jon on behalf of Expert Village in this video clip I will be taking you through our final procedure for making our sink drain better. Now that I have cleaned out the upper section of my drain I'm going to go ahead and test it again. That looks... Read More »
Hi! This is John on behalf of expertvillage.com. In this video clip, I will be showing you how to check for transmission fluid leaks. When checking for transmission fluid leaks, the first place I typically check is the seal, where the transmission fits... Read More »
Water Backing up Though hole in basement dynamis Plumbing 3 06-15-2009 07:11 PM
Washer tray drain plug proofer Appliances 5 08-24-2008 10:53 PM
sewer backup and stench jayhill Plumbing 12 08-14-2008 01:06 AM
Bath tub leaking through Drain nitu_752002 Plumbing 5 03-31-2008 11:22 PM
Drain clean out requirements steve1234 Plumbing 2 11-21-2007 01:06 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
