Old 06-15-2011, 10:32 PM   #1
Leaking inground pool light.
Please help! We are installing our DIY inground pool. The housing for the light is leaking. Thank goodness we have not back filled the light yet. I noticed it being wet, pulled all the dirt back and indeed a small amount of watter has accumulated under the light. It appears to be leaking at the bottom. The light cord has already been plumbed and is up above the water level so it is not that. I cant believe it is sealed with only 2 paper type gaskets while everything else in the pool is sealed with vinyl gaskets. Anyway, what is the best way to repair this. The water level is already way up over the light, so if there is anyway to fix it underwater we would like to go that route. Thanks for your help!!
Sara Holsenback is offline   Reply With Quote
Old 06-16-2011, 12:15 AM   #2
Doing it myself
Alan's Avatar
Just for the record, plumbers don't work on pools as far as I know, and if this is a DIY pool, it sounds custom.
Pictures would definitely be a great place to start if you're looking for some constructive advice. I can't even begin to picture what you're talking about.
Journeyman Plumber
Old 06-16-2011, 07:11 AM   #3
Lightfoot's Avatar
Electricity and water do not mix well. For the safety of all who will use the pool, call a pool professional and get it fixed correctly.
Lightfoot is offline   Reply With Quote
Pool parts...what is this for? tripflex Plumbing 5 02-17-2012 07:32 AM
Adding 2 more lights to existing light BCH_COLIN Electrical 7 01-24-2011 12:04 PM
Pool light voltage problem noquacks Electrical 5 12-24-2010 08:17 AM
Swimming pool light leak chrishim General Discussion 2 10-21-2009 10:52 PM
Replace pool light DONRILEY Electrical 5 07-20-2008 05:51 PM
