Leaking Hot Water From The Single Valve Kohler Shower Head - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-12-2009, 11:21 AM   #1
leaking hot water from the single valve kohler shower head
hi I am desperate to fix my shower that is leaking. I ordered a new cartridge from kohler and replaced it. the shower head still leaks, but it only leaks hot water. We don't know what else could be the problem. I tried googling the problem and I can't find an answer, except to replace the cartridge. We replaced the entire component. What do we do? The leak stops only after we shut off the hot water in the entire house.
B1026 is offline   Reply With Quote
The Following User Says Thank You to B1026 For This Useful Post:
DaleMullin (08-23-2013)
Old 12-12-2009, 03:24 PM   #2
Sounds like an o-ring on the back side of the new cartridge may have seated improperly when you pushed the cartridge in place?
Ishmael is offline   Reply With Quote
The Following User Says Thank You to Ishmael For This Useful Post:
Old 01-11-2010, 09:48 PM   #3
Same issue
We had a cold snap and it started afterwards. Got down to 16 in fort worth, which is really unusual. The pipe froze, or at least I think it did. I removed the face and turned a space heater on in the bathroom. I ran a hair dryer (set on luke warm) over the valve hole and the shower head for a couple minutes and the water began to flow gently, then at full force. Since then, I've had a hot water leak. If it is an o-ring issue, do we remove the valve and replace the o-ring? Is it that simple?
jobylewis is offline   Reply With Quote
Seal for a leaking hot water heater safety valve topspinken General DIY Discussions 9 10-14-2009 03:51 PM
Water heater keeps leaking out of TPR valve knac1234 Plumbing 10 08-14-2009 08:08 PM
main water supply valve leaking hohadcr Plumbing 10 07-31-2009 06:27 PM
Very Small leak at Shower Valve on Cold Water Side, Threaded. Tighten it more or ? twilightcall Plumbing 3 08-25-2008 08:19 AM
